Home Forum Ask A Member Elto Rudder twin timer bushing seems sloppy to me.
  • #9050
    huntleybill
      Restoring a rudder-twin and it seems to me that the bushing for the timer is awful sloppy. I have attached a video that shows what I mean. Is it supposed to be this sloppy? If not, how can I fix it?
      Video: https://youtu.be/RQGLWTb9r0w
      Thank you for your time
      Bill
      #70021
        I have not worked on them BUT is that screw an adjustment?
        #70026
        huntleybill
          Yes, it is an adjustment. I believe that adjustment is to give it friction so the timer won’t move on its own. I don’t think it should take up the slop…. should it? Am I wrong? Advice?
          #70037
          Monte NZ
            International Member
            That is the friction the adjustment screw and I would think that screwing it in would fix the problem.
            If that doesn’t do it, I would suggest you fit a suitable piece of shim metal as well.
            Monte NZ
            #70039
            Tom
              That’s pretty loose. It’ll work if you can use the tension screw to keep it in place, but it may drag on the tank.
              T
              #70073
              huntleybill
                I’ll see if I can find some shim material. If not I will tighten the tension screw. The motor probably won’t get near enough use to matter but since it is apart, might as well fix it right.
