Home Forum Ask A Member Elto Ruddertwin gaskets
  • #246683
    Brian McDougal
      Hi All,
      I have a 1925 Elto Rt that has original paint that looks great. I don’t think its even been apart. I can see that the pistons have some carbon build-up on them and wonder if I should take it all apart and clean everything up? What are the jug to the block gasket like? Metal? Where do I find them, or do I hammer out my own?
      #246688
      RICHARD A. WHITE
        one can hammer out your own pretty easily…. I did that one my first one… worked very well
        classicomctools@gmail.com
        #246691
          If you remove the cylinders and don’t replace
          the gaskets with material of the same thickness
          the exhaust manifold wont fit. Today’s oil will
          do wonders to remove the carbon deposits from
          the oil of the past. Also if you don’t install
          the rings exactly as the are now they will be
          no longer seated although I believe there are
          pined and that shouldn’t be a problem.
          • This reply was modified 4 years, 6 months ago by Tubs.
          #246692
            #246698
            eltoquad
              I’d leave it as is and run it . I doubt that carbon will have any effect on it unless exhaust ports are really carboned up. Running it with todays oil could even help clear some of that out.
              #246699
              Brian McDougal
                Thanks Guys. Yeah, I didn’t know if the head gaskets were something special. As far as the oil goes, can I use 2 stroke oil mix or use old fasion straight 30w? Maybe I’m being to annaul.
                #246701
                  They didn’t have 2 cycle oil in 1925
                  but they do now and that what I use
                  in my Super Eltos. How about the gear
                  case. Have you cleaned it out and
                  filled it with fresh 105 or corn head
                  grease?
                  #246702
                  Brian McDougal
                    Thanks Boat House. I was going to use a “red grease”, Multiplex 220, #2. I never heard of corn head grease.
                    #246703
                    Brian McDougal
                      I found it Boat House. Thanks for looking out for my Elto !!
                      #246704
                        Here is a short video I made that demonstrates
                        why we use those products today.
                        https://youtu.be/dAu2-zYmgGc
