Home Forum Ask A Member Elto Ruddertwin wires
  • #188201
    muddog2
      I don’t know if the coil is good or bad, but the insulation on the wires are brittle. Can I cut them off within an inch of the coil and solder new wires on and cover solder joint with shrink wrap? I have a video off of youtube that shows how to rebuild the coil with an inexpensive military 2 cycle coil. I want to try to get this motor started.
      Thanks, Robert
      #188207
        Of course that will be a temporary fix – they will sill be weak where they exit the coil container.
        #188210
        wbeaton
          Hard to get a good solder bond on old wires like that. The condenser is probably bad after 90 years. Those are two reasons why I rebuild the ELTO coils.
          Wayne
          Upper Canada Chapter
          uccaomci.com
          #188212
          lyks2tinkr
            In my experience with many of these Elto coils is that the secondary is actually good. It’s the internal capacitor (condensor) that is faulty causing a no spark issue.
            I replace the timer and battery cables and the spark plug leads while I have it open.
            The original Elto coils give a nice fat spark.
            #188218
            muddog2
              Thanks, Robert
              #188221
                #188245
                RICHARD A. WHITE
                  I have like 5 of these I am tinkering with… Boiled them and actually lost one housing…not sure what happened but the housing seemed to be kind like paper… So to replace it I am using 2 1/2 OD Delrin bar stock bored out and I will then make end caps our of same…
                  classicomctools@gmail.com
                  #188271
                    #188273
                    muddog2
                      Great information. Thanks again
                      Robert
                      #246435
                      Brian McDougal
                        Hi Boat house. why are all your images gone? Man, you sure have the knowledge. I wish I could see what you post. Thanks, Brian
