Home Forum Ask A Member evenrude sportwin model 4423
  • #253163
    JEFFREY PLITT
      hey guys . I’m buried again in carb trouble . working on this odd ball carb . not sure about the plungers for the primer . is there any special order ? I cant get a squirt of gas . i also believe i am missing the carburetor venturi according to the diagram . thanks in advance
      #253170
        Regarding the primer / plunger. Does the Sportwin 4423 have the rubber
        cups like the Zephyr? I can’t remember, but there are tiny hydraulic cups
        “out there”. (The part number eludes me at the moment)
        that can be modified for the Zephyrs.
        Photos of some other “data” I had……
        Air Shutter alignment marks
        4423-Air-Shutter-Alignment-marks
        <hr />
        Carb Cut-away
        4423CarbCutAway2
        4423CarbServicebulletin
          I found the primer cup data, from Mumbles….
          Zepher-primer-seals
            The 4423 and Zephyr primer cups are two different sizes with the 4423 one being slightly smaller in diameter. I never did find a correct replacement for the Sportwin so there she sits, hanging patiently up in the rafters in the garage.
            Kind of nice to see a throwback to the old boards with blue and comic sans script
