Home Forum Ask A Member Ever seen a Frankentank?
  • #2243
    beerman57
      Someone has too much time on their hands.
      http://www.ebay.com/itm/Vintage-Evinrud … 74&vxp=mtr
      #21900
      wiscoboater
        I’ll bet that seller does not even know it’s been modified.
        #21901
          I guess that must be a "fits all" tank, look like it was set up to work as a single line, or pressure tank. Wonder if it works as intended!
          #21902
          Doug Wilson
            never seen that tried would think it might not hold pressure too well but never know
            Doug
            turned off?
            #21952
            dan-in-tn
              If everything works as intended it should work. OMC went to tanks that let air in, but no fumes out when they put the vent in the single line fitting on top of the tank. Can’t tell if this is one of those? It is the no vent cap! It would have been nice to use an upper housing (dual line) that had both ears broken off to add more symmetry, but I guess that is in the eye of the beholder. Not sure the newer tanks were built as think as the pressure tanks?
              Dan in TN
              #21974
              1946zephyr
                Now, if THAT doesn’t look ridiculous LOL 😀 😀
                #22038
                William Jatzek
                  I think that tank is quite ingenious. One tank can do it all. Bill,
