Home Forum Ask A Member Evinrude 10 HP 1957 Model 10014
  • #219148
    Evinrude 25
      Hello,
      I just pick up Evinrude 10 HP 1957 Model 10014-10015. Compression check is 60/60 psi per cylinder since it sat long outside. Spray some WD-40 inside the spark plug hole and got 70/71 psi.
      I would like to know if it is an acceptable compression before I tear down to restore it.
      #219150
        My 10hp Johnsons both run real good with about 80-83psi. If your motor sat idle for a long time, it might just be stuck rings. You might try to get it running with fresh fuel, oil and some BRP Engine Tuner and see if compression doesn’t come up a bit more. You can also pull the bypass covers off and push in on the piston rings to see if they have any spring or bounce to them. If not, then they are stuck.
        #219152
          Or a blown head gasket .between the 2 cyl.’s
          • This reply was modified 5 years, 4 months ago by DAVID.
          #219157
          Evinrude 25
            Does anyone know the factory compression number? 90 psi when brand new? I am planning to hone the cylinder and fit the new rings for it but I have to do some search for the ring part number.
            #219159
              I doubt it needs rebuilding…Might be your gage is inaccurate… Like Bob says, you can sneak the intake covers off pretty easily without making a mess, you might try peaking at the intake sides of the pistons…But, it sure couldn’t hurt to pull the head to have a better look.
              Once again, I would not pull this powerhead apart unless you find evidence of actual damage or stuck rings….
              #219177
                just run it as suggested with some kind of decarb agent (Seafoam,MewrcPOwer tune, Evinrude engine cleaner etc….) don’t fix it if it ain’t broke 🙂
                #219357
                Evinrude 25
                  Open the intake cover, the ring and piston looks clean and no carbon deposit. Open the head, the cylinder looks good too.
                  #219359
                  seakaye12
                    Through the intake cover you should be able to use something to poke at the rings; you should see movement…a slight springy action as you depress them in their grooves. If you see that, the rings are not stuck.
                    #219365
                    Evinrude 25
                      Yes, I could move the ring by poking at it. It moves back and forth freely. Let me try to fire it up with 70 psi/68 psi of compression. Even I spray more WD-40 on the side of the ring through the intake cover, no improvement on the compression! The top crank shaft seal got leak too. It is time to replace it.
                      #219402
                      amuller
                        If it were mine I’d run it under load for a while, dosed up with the OMC engine tuner stuff. It’s not unusual for this to free up mildly stuck rings. and gaskets/parts are getting more and more expensive. And I dislike messing with a bunch of loose needles. You might feel differently. Of course, you probably can’t run it under load in a tank, so if you are into winter (which we definitely are in Minnesota) and you want to have it ready for next season….
