Home Forum Ask A Member Evinrude 1967 40hp Lark IX Restoration (40773 E)
  • #205249
    KyleTheJuggler
      Hi, I was just wanting to know if anyone has any recommendations for getting this engine back up into running conditions. Its spark plugs have been recently redone along with the starter. Seemingly has better compression in one cylinder than the other, just really looking for recommendations and some background knowledge on the engine. (It is currently on the back of a 1967 GW-Invader that was my grandfathers and I want to restore it back to its natural greatness.
      #205268
        Evinrude’s bread and butter during the 1960’s. I guess you already know that it is Selectric Shift. Must use correct oil in the lower unit. The push button switch in the control is rare and expensive (and somewhat failure prone. The junction box on the transom is prone to flooding on a boat such as that, and the voltage regulator is in that box. Also expensive.
        Overall, a great motor, but condition is everything.
        What is with that cobblrd-up Morse throttle control cable?
        EDIT: Well beat me with a stick. The 1967 didn’t have a junction box, did it? That’s a good thing in your favor.
        • This reply was modified 5 years, 8 months ago by frankr.
        #205282
          These were great motors for sure, but like Frank says, you must make sure all the electrical wiring/harnesses/switches are in serviceable condition. That engine looks like it might have lived a tough life though…
          Is this a fresh or salt water engine? Salt water engines are very difficult to repair due to rusted hardware and corroded castings. The salt water is real tough on the wiring and connections also. This electric shift engine is pretty much useless if the wiring is not in good shape. The generator has to work also.
          So, where to begin…
          You mentioned uneven compression….Do another compression test, can you make the electric starter work? Pretty tough to do a good compression test on this engine without using the starter motor.
          Next, drain and inspect the gear lube. This electric shift engine relies on clean/water free gear lube in order for the electric shift mechanisms to work properly. There are two drain plugs in the gearcase. For now, just crack open the lower drain screw and see what dribbles into a clean pan. Milky or raw water dripping out spells trouble. No need to drain completely, all the crap will be at the bottom of the gearcase, reinstall the drain screw after letting just a bit dribble out.
          Let us know what you find….D
          • This reply was modified 5 years, 8 months ago by Don. Reason: correction
