Home Forum Ask A Member Evinrude 4207 Sportsman carb adjustments
  • This topic has 1 reply, 2 voices, and was last updated 4 years ago by Tubs.
  • #255499
    sdgloo
      Re; Evinrude Elto Sportsman 4207 poppet valve adjustment.
      can someone help with “ how to” adjust the poppet valve spring. I’ve assembled the valve and measured the pressure to open the valve . Specs are 3 oz but mine takes 4.6  oz to open. My trouble is with keeping it running below half throttle, in spite of needle valve steering. Can this effect operation or should I ignore?
      thanks in advance
      #255500
        If the spring shows no indication of being altered
        (stretched) I suggest you look else where. Most
        likely compression. Typically these are found
        having around 60 lbs. While they will still start
        and run, its not enough for them to run properly
        in the mid to slow range.
