Home › Forum › Ask A Member › Evinrude 4305 Sportwin Condenser
- This topic has 9 replies, 5 voices, and was last updated 8 years, 7 months ago by
garry-in-michigan.
August 1, 2017 at 6:06 pm #7800
Looks like I need a new condenser for my Sportwin now. When it’s cool and I crank it over, it’s got a nice fat spark, but after about a minute of running it starts running rough and loses spark. Anyone know what condenser will work? Everything else seems to be good, the carb is good, and it’s pumping a lot of water.
August 1, 2017 at 10:43 pm #62498Here are the Evinrude/Elto capacitor specs. A modern capacitor is great. If you want to preserve the authentic look, the shell of the original part may be used to house the modern eqquivelent. . . 🙂
August 3, 2017 at 3:14 pm #62546Here’s a link to Digi-Key for a modern 0.1 uF capacitor for your ’39 3.3 horse motor.
August 3, 2017 at 4:07 pm #62549Awesome! Thanks a lot!
August 17, 2017 at 4:39 pm #63311I decided to go with a Briggs and Stratton condenser instead of one of the others. It’s a .22uF, which I wasn’t sure would work, but I had one laying around, so I threw it in anyway. Works a treat and is a direct bolt in! I don’t have a part number to share, but they make them new and it’s made for loads of B&S engines from the 30’s through the newer 5hp flatheads.
August 18, 2017 at 1:06 am #63335If the capacitance is way off, the motor may run OK but there may be excessive metal transfer from one point to the other.
August 18, 2017 at 2:44 am #63347Can anyone post a picture of a new Capacitor in an old ‘shell’ that Garry refers to?
August 18, 2017 at 4:18 am #63352It would look just like the old capacitor. . . 🙂
August 19, 2017 at 5:55 pm #63453So, I’m guessing I would pull out the innards of the old condenser, clean up the inside, drill a hole in the far end and put 1 wire through to go to the mag plate where the old condenser would attach, then the other wire to the points; and use silicone gel/caulk to hold the new capacitor in place inside the old can. Should I insulate the wire to the points? Thanks for the help.
August 20, 2017 at 11:43 am #63500You Got it – I use shrink tubing on the condenser {capacitor) wire so it is totally isolated from ground. . . 😀
