Home Forum Ask A Member Evinrude 5.5
Viewing 10 posts - 1 through 10 (of 21 total)
  • #234890
    james hobson
      What’s going on my 1956 5.5 I set the points at 20 tho right between the two marks on stator plate rebuilt carb but when I run motor at full speed it will only run best when high speed needle is almost fully seated what gives should it not be open at least a quarter to 3/4 turn open.
      #234891
        Well, are you sure the high speed needle is seating properly and not damaged? How about the thick nozzle gasket, is it is place, in good shape? If the nozzle gasket is missing/messed up it will cause the engine to run rich at high speeds…Turning the high speed needle all the way in compensates for the extra fuel leaking into the high speed nozzle well…
        #234977
        mercuryman
          I agree with Fleetwin
          #234984
          james hobson
            So not the red gasket but the thick one
            #234987
              There is a thick little nozzle gasket, almost looks like a squared off donut…Post some pictures if that will help us clarify things for you…
              #235028
                see picture
                #235167
                james hobson
                  Ok guys I am at a loss rich condition still persists , I took carb apart looked everything over hi speed needle looks good not bent no wear both seals in place also looked at float level it is good not hanging up nozzle tight thick seal in place not damage I had rebuilt carb I soaked clean blew out I know it was spotless inside however still runs to rich have to run with high speed needle fully closed, oil mixture is 24/1 what else should I look.
                  #235175
                    Did you install a new 439071 carb kit or are you using the old parts in it?
                    It seems the carb is getting too much fuel so I would suspect the float valve might be leaking, especially if the float height is set correctly. If the brass seat was removed, there is a thin sealing washer which must go back in again and the seat must be tight, not snug, to prevent any leaking past the sealing washer. The tip of the needle may be worn or damaged to, along with the surface in the seat it rides on. Any dirt or fibers in the seat area will also cause fuel to leak past. How’s the float? It may be soaked with fuel and be too heavy to close the valve at the desired time.
                    Can you post some photos of the inside of the carb and bowl?
                    #235183
                    outbdnut2
                      Hold the carb upside-down so the float valve is shut and see if you can blow into the gas line – you should not be able to.
                        carb bugs… with or without a fuel bow did you clean the small holes on the HS tube going up the carb … they help vaporize the fuel
                        • This reply was modified 4 years, 11 months ago by JACQUES.
