Home › Forum › Ask A Member › Evinrude 7516 Fleetwin Clam Shell hood pin
- This topic has 7 replies, 3 voices, and was last updated 9 years, 1 month ago by
Buccaneer.
February 1, 2017 at 5:10 pm #6248
I was thinking about removing the pin from the clam shell hood
to separate the two halves to make it easier to remove
the old paint, repaint, etc.
One end of the pin is in a blind hole, hence there’s
no way to drive the pin out.
I tried grabbing the pin with a pliers and tapping
the pliers with a hammer, to no avail.
What’s the secret?
Thanks!Prepare to be boarded!
February 1, 2017 at 5:17 pm #52249Cut it between the hinges. After separating the two halves, the end in the blind hole can be drilled out and epoxy will hold the new pin in place. You might have to make up a long drill bit to do this. I’m pretty sure the pin size is 3/16 and I’ve used aluminum rod from a welding shop for a replacement.
February 1, 2017 at 7:41 pm #52261Thanks Mumbles! I’m guessing Evinrude wasn’t
planning on these ever coming apart!Prepare to be boarded!
February 7, 2017 at 12:37 am #52552I separated the hood halves today. It didn’t go quite like I planned.
I hack sawed the pin between the hinges on both ends, and separated
the hood halves…. so far so good.
I tried to drive the pin (in the through hole) towards the middle. Found
out that it only drives to the outside of the hinge, or toward the front
of the hood, as the end of the pin is knurled.
One piece of the sawed off hinge pin out, one to go.
Went to center punch the remaining pin (to drill it out) in the blind hole, barely
tapping it, and the pin went 1/4" deeper in the blind hole.
Therefore, it was only the knurled end of the pin in the front of the
hood that was keeping the pin from falling out.
Tried tapping the hood with a hammer, etc., and the chunk of pin in
the blind hole would not fall out.
Finally took a 1/6" drill bit and drilled into the hinge where I thought the
end of the cut off hinge pin would be. Then used a probe and
compressed air to work out the piece of pin.
Now that I know this, the next one will probably be put together differently, lol.Prepare to be boarded!
February 7, 2017 at 1:38 am #52556I took one of those apart once. And I learned not to do that again. (It was a salt water motor)
February 10, 2017 at 2:38 am #52718I had an old fuel oil tank gauge that I saved to my scrap pile years ago.
Finally came in handy. It had a 3/16 round, steel rod in it, about
24" long. Perfect for a replacement steel hood pin that I hack sawed
to pieces……. and I got enough left for two more hoods!Prepare to be boarded!
February 10, 2017 at 3:16 am #52722Wasn’t your original pin aluminum? Steel might leave rust stains all over a new paint job.
February 10, 2017 at 12:41 pm #52734Mumbles, negative on aluminum…… a magnet
was very attracted to the old pin, and I don’t
remember seeing rust on it either.Prepare to be boarded!
