Home Forum Ask A Member Evinrude 9.5 powerhead isolation
  • #281455
    JOSEPH BRINCAT
      Hello all, I’m helping a friend with a 1969 Evindude 9.5 model 9922S, that is the motor with the low profile enclosure shroud. I see that the powerhead is rubber mounted for isolation but geez there seems like an excessive amount of free movement. I can move the powerhead about 3/4 ” fore and aft with in the shroud before I encounter hard stops. Does that seem right? My first-time encounter with this model, so I have no point of reference.
      Thanks,
      #281457
        I believe these motors are well known for their rubber mount failures.
        I see yours has the vibration dampers as well as the rubber mounts.
        I believe OMC added these dampers as the earlier models had
        lots of “shaking” problems.
        I went through one in the past, and there should be a thread on it
        in “Current Projects”, showing all the rubber mounts, etc.
        JOSEPH BRINCAT
          Thank Bucc, yes this has a sliding damper on the starboard side of the powerhead. I’ll look for your posting
          #281463
            my 9.5hp is at the cottage      going from memory.. i think 3/4 inch movement  is ok these turtles flop around
            my 9622a  does anyway but it works fine…but I did  take it out  and popped in a Merc 4hp…smoother and  cheaper on fuel  for trolling all day long
            #281471
              3/4 fore and aft is a broken upper front motor mount. l’ve replaced lots of them back in the day.
              #281510
              JOSEPH BRINCAT
                Thanks Frank. So now I have to figure out how to get to this motor mount. I suspect that I have to open up the entire “clam shell” housing. See what other complications that involves. My first time with the low profile motor, learning!  Any info on a part number would be helpful.
                #281514
                  Yep gotta shuck it out of the shell
                  I suppose marineengine has the parts list posted but haven’t looked
                  #281516
                    try utubes for tear down ..of the 9.5
                    #281517
                      previous reply got spoofed ???
                      2nd try…
                      ok  i’ll have to check mine for  3/4 ply although I did not notice  any problems.  gotta hurry … winter is creeping in
                      #281518
                        In case you didn’t find it, my thread on the subject motor……..
                        Bunches of photos showing the mounts, etc.
                        https://www.aomci.org/forums/topic/evinrude-johnson-low-profile-9-5-hp-adventure/
