Home Forum Ask A Member Evinrude Cub Flywheel Removal
  • #269943
    Terrel Beckham
      I’m working on a half horse Evinrude Cub.  I don’t see an easy way to remove the flywheel (I need to troubleshoot the ignition).  I have two pullers.  One uses threaded holes the other grips the edge of the wheel.  Neither will work with this design.  I have the crank nut off.  Any hints?
      #269951
        You need to make up a flywheel popper.
        Basically a nut that screws onto the crankshaft with
        a bolt on the top of the nut. Some people weld up
        a double nut, but I got by on this motor with a single
        nut, threaded half way onto the crank and bolt, the
        snugged up good.
        Then lift the motor by the flywheel while someone smacked
        the bolt with a hammer. I was all alone, so I got by lifting
        the motor by the flywheel with a clamp.
        You want to lift the flywheel before you smack it to avoid
        damage to the insides of the motor.
        https://www.aomci.org/forums/topic/1941-42-evinrude-sportsman-4366-2-hp/
          Loosing the flywheel nut and taping on it
          while lifting up on the flywheel may get it off
          if its not too tight. If not you want to use this
          method. It is very easy to damage the
          end of the crankshaft on these. This method
          will prevent that if done properly. The nuts are
          small so just jamming two together probably
          wont work. You may need to weld them together.
          After each strike with the hammer you want to
          check that the tool is still tight.
          https://youtu.be/RWgE9XiIBnk
          • This reply was modified 3 years, 3 months ago by Tubs.
