Home Forum Ask A Member Evinrude Elto, Opposed, Handitwin Coil
Viewing 1 post (of 1 total)
  • #244384
      Had the “new to me” subject motor running this morning,
      but it did not want to restart when warm.
      Decided to take the mag plate off, check it out,
      install a new capacitor, etc.
      Was saddened to see my ohm meter show “Zero” ohms
      on the secondary. Primary was .1 ohms.
      Tried a different meter, same ting.
      Hooked the coil up to my Stevens’ tester, and coil
      fires at about 1.5 amps, and probing on the tops side
      of the coil found no leakage.
      Guessing the secondary winding is “open”, but the Stevens
      is jumping the gap……. beginning to wonder what good
      the Stevens’ tester is?
      Started thinking about substitute coils, but not sure of
      a modern alternative. Anyone know?
      I looked at a Zephyr coil, but it’s about 1/8″ longer, and
      the inner core laminate is quite a bit different.
      Thoughts? Thanks.
      DSCN1582
