Home Forum Ask A Member Evinrude Fisherman
  • #267235
    geary
      Guys,    I found an Evinrude Fisherman, model no. 4269  00200 and wondered if anyone could tell me some of the specs of this engine ?  Is their anything special about it ? What year is it, what’s the hp, cubic inch displacement.
      I’d like to make this a good running engine, clean and repaint also !  Thanks for any help you can provide !
      Gary
      #267238
        Model #4269 would be year model 1938, 4.7hp.
        #267239
        Tom
          Well… it’s heavy.
          It’s a 1938 4.7 hp opposed twin cylinder motor.  The brass lower unit makes it more collectible than the standard one.  I believe it has a poppet valve carburetor, which has a very unique sound as the valve bangs up and down.  Powerhead parts, such as the coil, are common to other motors.
          To test the coil, measure resistance between the two high tension wires, not one at a time to the block.  Don’t check for spark on either side without grounding the other side (or check both at the same time).
          Keep us posted.
          T
