Home › Forum › Ask A Member › Evinrude Mate 2
- This topic has 15 replies, 8 voices, and was last updated 3 months ago by
Don.
December 28, 2025 at 3:20 pm #302706
I just posted a long response to this, tried to update/correct a little grammar, then repost, seemed like it disappeared. Hoping it will magically reappear…. Many things to consider here..
How many links.? I believe 2 are safe. 3 maybe one time. If you try to make a correction it thinks its spam being re-posted. Then it goes into quarantine until someone releases it. This is my best guess as far as my experience.
OK, so it will reappear after someone approves it then?
OK, my post just reappeared…
December 28, 2025 at 6:40 pm #302717
That is what I suspect will happen. These conclusions I have offered are based on my experience. I don’t have any actual knowledge as to what is occurring here and it doesn’t seem that those who should have any interest in at least inform us as to what causes this so we could possibly avoid it.
December 29, 2025 at 11:35 am #302737Tubs and Fleetwin….. (et al….)
I am one of the moderators who “approve” posts that get quarantined. It is a manual process that involves looking at a Topic/Reply summary and noting if there are any posts quarantined. I try to do that on a daily basis but of course it gets forgotten now and then.
It is as much a mystery to me as to anyone how or why certain posts get quarantined. Sometimes (maybe most of the time) it involves links….but not always. Sometimes it is a real head-scratcher as to why a post gets quarantined.
Feel free to send me a PM or e-mail or phone call if this happens as I get no “notice” from the site.
Chuck Kober
December 29, 2025 at 12:06 pm #302739
In case you’re not aware that Fleetwin’s reply has appeared, here it is. .
OK, so you are saying that the crankshaft is seized into the lower bearing/seal assembly? Were you able to remove the four retaining bolts for the lower seal housing? Did you remove the piston/rod? If so, that crankshaft will just push out of the bottom of the crankcase taking the lower bearing assembly with it. It might be best to place the block in a press to drive the crank/lower bearing housing out of the block. Once out of the block, you can flip the crank/bearing housing upside down, put it back in the press, using a simple spacer sunk/bottomed into the crank splines protruding out the seal housing to separate the crank from the seal housing.
Unfortunately, I’m guessing neither of those two parts will be much good. Going much further with this project seems like a questionable endeavor unless you just want to enjoy resurrecting one of these engines. What condition is the rest of the engine in? Fresh or salt water use? The critical piece on this thing is the darn steel fuel tank. You are pretty much SOL if the tank is rusted/fouled, although I have converted one of these engines to the newer style with the plastic tank.
The best bet here would be finding another 2hp with a decent powerhead, but they are getting more rare and folks seem to think these things are “gold” they way they price them. Just keep looking on CL/FB, something will turn up for a reasonable price.
Keep in mind that these engines have no oring on the upper driveshaft to protect the splines, so worn/rusted splines are common. The best powerhead on earth is useless if the crank splines are rusted/worn/spum out.
December 29, 2025 at 3:13 pm #302750Tubs and Fleetwin….. (et al….)
Chuck Kober
Thanks Chuck
My post reappeared relatively quickly. Now that I know, I will not worry when I edit/correct my posts. Don
