Home › Forum › Ask A Member › Evinrude model U
- This topic has 5 replies, 4 voices, and was last updated 6 years, 4 months ago by
2fast4me.
October 6, 2019 at 11:50 am #184712
1928 Evinrude Model “U”……Morning everyone my question of the day is What is my spark plug thread…… It’s too large for 18 MM……. I have some pipe thread plugs it to is wrong and the pitch is wrong……
I want to fabricate a plug for the “grease gun method” to free the stuck cylinders. I don’t want to destroy my existing plugs as They may be useable. Thanks Jim2Fast4Me
This topic was modified 6 years, 4 months ago by
2fast4me.
October 6, 2019 at 12:55 pm #184723I believe that one is 7/8-18. Try to find a take-apart plug that size, find someone with a lathe, and replace the porcelain with an insert tapped for a grease fitting.
T
October 6, 2019 at 9:28 pm #184757Thanks Tom, i can handle the fabrication part if i can find the spark plug. I had no idea this size existed.Jim
2Fast4Me
October 6, 2019 at 11:23 pm #184760Same size as used on Model A Fords. You might try Summit Racing to find them.
"Every time you remove a broken or seized bolt an angel gets his wings."October 7, 2019 at 10:32 am #184784All the old “take apart” Champion plugs I have are 18mm. You are supposed to replace the copper washers on either side of the ceramic each time you took them apart to clean off the carbon. . impossible to find these washers today. – Some of the first Row Boat Motors were threaded to accept the ceramic insert held in place with a jam nut. These were developed as “Igniters” for the”coal oil” fueled steam engins of the day.
This reply was modified 6 years, 4 months ago by
garry-in-michigan.
October 7, 2019 at 10:19 pm #184825Thanks for the help Bob- looks like model A 1928-1931, Tom right on with the size, i verified it while at work. & Garry, I’ve got some of those “take apart” models also and thanks for the extra info.
I’ll prolly just order two new ones and get the process started.2Fast4Me
