Home › Forum › Ask A Member › Evinrude Parts
I am looking for a source for parts for a 1955 Evinrude model 15014 Need head gasket and lower unit pinion gear.
Thanks
John
Try these guys
http://www.myoldboatmotor.com/motors-.html http://www.vintageoutboard.com/
I’ve had dealings with both. Top shelf, both of them
Try an authorized Evinrude dealer. Many will order it for you…..support your local business when you can.
The head gasket is P/N 203247. The pinion gear is part of a set P/N 375844.
I have a complete gear set from the slightly later model. The case is shot, but the gears are good.
Thanks for all the info. Found a gear set locally this morning. Will try ordering head gasket
OK
