Home Forum Ask A Member Evinrude RBM piston rings
  • #238538
    Bill Roth
      I had a stuck piston on a 1914 Evinrude and using the wax method we finally got it out. While cleaning the piston I may have stretched the lower ring to much loosening it up. These rings are pinned to the piston. Has anyone found a safe way to get it back close to specs? I was thinking of clamping it and applying heat, but will it go back to closing the gap or create a bigger gap?
      Any ideas would greatly be appreciate!
      Bill in MN at: anbroth1544@gmail.com
      • This topic was modified 4 years, 10 months ago by Bill Roth.
      #238547
      Tom
        What makes you think it’s stretched? Unless it’s been heated a lot, stretching it without breaking it is unlikely.
        T
        #238564
        RICHARD A. WHITE
          With no disrespect to you, the rings are intentionally bigger than the bore when relaxed. That is so that they “ride” on the cylinder walls to give the compression needed to keep the engine running.
          My experience is that if I work the ring too much trying to remove it…they break…. makes me say bad words, but then it is always my fault they break.
          Put the ring in the bore, by itself, use the bottom of the piston skirt to ensure it is true in the bore, measure your end gap to proper specs, if it is the range, reinstall it on the piston an go.
          Regards
          Richard
          classicomctools@gmail.com
          #238641
          PM T2
            I would have to say that it’s practically impossible to bend these rings enough to actually spring them out of spec. Trust me when I say that the ring will tell you in its own special way that you’ve over-stressed it in an outward direction because you will turn a single-piece ring into a two-piece that requires an impossible do-it-yourself assembly job to make it useful again.
            Put it back in its groove, compress it properly, and reinstall it in t he bore and things will be fine.
            Hope this helps.
            Best,
            PM T2
            #238710
            Bill Roth
              We found that It wasn’t stretched. Yesterday with a second set of hands we were able to compress it and tap it in. Thanks for your comments!
              #238711
              Bill Roth
                Got the piston/rings in with a second set of hands and a little tapping. Thanks for you suggestions!
                #238742
                RICHARD A. WHITE
                  Awesome…..
                  #239150
                  Bill Roth
                    Regards
                    Richard
                    Took your idea and that worked. Thanks
                    #239153
                    Bill Roth
                      Regards
                      Richard
                      THANKS
