Home Forum Ask A Member factory bore specs for a 1957 18 Johnson?
  • #250031
      I am finally getting back to looking into having my FD block bored .020″ oversize. Does anybody have factory the bore spec for this engine? Obviously, we would add .020″ to that spec! I remember hearing once that, unlike automotive, you shouldn’t just hand the piston over to a machinist an have him bore it according to the piston, because the running clearances are different than automotive. All thoughts welcome.
      #250033
        Piston to cylinder clearance 0.003″ min, 0.0045″ max, AT THE SKIRT (they are tapered).
        #250076
        johnny
          Factory Bore is 2-1/2″.
          #250079
            Thanks, both of you. Good info. I appreciate it.
