Home Forum Ask A Member Factory set needle valve.
  • #234686
    russ
      I have a 1972 Evinrude 6hp that has the factory set needle valve.Can someone tell me abouy how many turns out I should start at? Seems almost closed. Thanks Russ…
      #234687
        Russ, are you referring to the adjustable low speed needle valve at the top of the carb? If so, the initial setting is 1.5 turns out from gently seated….
        #234747
        russ
          Yes that is the one. Thanks fleetwin…
