Home Forum Ask A Member FDE 11 Piston me Off
  • #10009
    effenaco
      My FDE 11 needs a new piston so I decided to replace the set. Original part number was 376992. It has been superseded by 385338. I ordered a set of these and when I got them they are 2 ring pistons, not three ring pistons which are currently in the motor. Does anyone know if this is a correct replacement and will there be any issues if it is OK to convert? OK experts, weigh in and let me know. Thanks
      #76584
      retiredoz
        Unless the picture is wrong ?
        http://www.marineengine.com/newparts/pa … OMC0385338
        In any event, that’s what my ’75 Johnson parts book calls for for your FD-11.
        #76585
          They went to two-ring pistons a long time ago. No problem. Actually, pressure back rings came later on.
          #76586
            Deleted duplicate post
            #76601
            effenaco
              I bought the replacements from Marinengine.com based on that picture, but what arrived were two ring pistons. Then I bought another on ebay and same thing, two rings.
              #76619
              retiredoz
                My ’69 parts book lists this piston for your FD-11 (383476)
                https://www.ebay.com/itm/CLEAN-1969-197 … SwIGJaN-pY
                #76967
                effenaco
                  Yes looked at that one as well. Still two ring even though pictures everywhere show it as a three ring. Again my question is, will there be any problems or other modifications needed to swap the three ring pistons for two ring?
                  #77006
                    No problems at all. As long as the pistons are properly fitted, two ring pistons are thought to be fractional more efficient (Less drag) than three ring pistons. They are favored in racing motors. Also, adding rings does little to help a poorly fitted piston. . . 😎
                    #77120
                    effenaco
                      Garry,
                      Thanks. I just wanted confirmation from an expert. Hope all is well.
                      Barry
