Home Forum Ask A Member Flywheel, crankshaft
  • #72360
    Alan Pelot
      Thanks guys. The o.d. was .020 larger on top I ran a chaser down it and the threads cleaned up nicely. I still don’t have the flywheel off. I tried both styles of pullers. I am gun shy now. Afraid to crank on the puller to much even with the flywheel nut in. Never had one stubborn like this, normally they pop right off.
      #72361
        make the nut flush and don’t worry tighten and let stand over night if needed then repeat as needed.
        #72362
          #72364
            I agree with Dave.
            Put the nut on flush with top of crank.
            Install puller. Use grade 8 bolts. Install them all evenly into the flywheel. Ensure puller is level before cranking on center bolt. Tighten her down. Pull UP on the flywheel , and give puller bolt a rap. Not a sledge hammer type smash, just a rap with your hammer. I like the OEM puller as it has a handle to hold flywheel from turning while I pull on wrench on center bolt. Sometimes, I have had to add a bar to the wrench to give me more pulling torque to make her pop. If all is installed properly, should pop right off.
