Home › Forum › Ask A Member › Flywheel puller for mark 5
I’m having trouble removing the flywheel. I built a custom flywheel puller however the threads in my metal plate broke. Any suggestions on how to find/make one?
L
The threads on my crankshaft are not damaged. Its the threads on my makeshift flywheel puller.
drill your tool to let the bolt go thru. then use a nut under the plate. that way it can be replaced at any time. you will need 2 wrenches.
Would agree with Dave on that one should work fine
Doug
how is it motors multiply when the garage lights get turned off?
https://www.amazon.com/TruBuilt-Automot … ear+puller
$14.25 Amazon
Or make yourself a flywheel knocker. Works great for small motors. See this old thread which includes pictures and instructions:
viewtopic.php?t=6119
JP
OK
