Home Forum Ask A Member Fuel connector for 1950's Evinrudes
  • #174954
    benji41
      Wanting to know if this is the correct part number and where I could get one. This is the connector for the fuel hose on the fuel line. Part number—375788
      Jim Benjamin
      #174956
      outboardnut
          If you want the connector which goes on the fuel/air lines, and not on the motor, it’s P/N 375587/376341 and can be found on fleabay for anywhere from a few dollars up to a few hundred dollars. You have to shop around!
          #175074
          benji41
            Thank you for the info and part numbers. I have found what I need ehit your help
            Thanks again
            Jim Benjamin
            Jim Benjamin
