Home Forum Ask A Member Fuel Hose
  • #229758
    yooperrigged
      Hello,
      I plan to replace the fuel line on my CD 13A. Has anyone used the yellow tygon fuel line? I think the ID is 1/8 in. and it seems a bit more flexible than the black hose which is hard to get over the fittings. If you have any experience with the tygon hose any advice is appreciated. Thanks. Dan
      #229761
        some do not recommend it use the good stuff apply grease to fittings to slide over use proper dia. hose
        • This reply was modified 5 years, 1 month ago by JACQUES.
        #229773
          Genuine Tygon is excellent fuel hose but some don’t like using it as it doesn’t appear original.
          #229782
          yooperrigged
            Fuel hose certainly isn’t a big ticket item…the tygon from Advance Auto Parts is under $3 a foot. The black hose is cheap too of course. I was thinking it may be easier to install with my sausage fingers.
            #229821
            rudderless
              It is a lot easier to diagnose air leaks with see thru fuel hose like tygon
