Home Forum Ask A Member Fuel Pump recommendations for Johnson FD 12 conversion
  • #275811
    DrummermanBob
      Will the Sierra 18-7350 Fuel Pump work as conversion pump for Johnson FD12 18 hp?
      #275813
        It would require an intake bypass cover with the correct fuel pump mounting holes.
        #275814
          I just completed a fuel pump conversion on my FD-12 and used the Sierra 18-7350 pump.   As Frank noted, you need the intake bypass cover from a 1960 or later motor, OMC part number 307477.   Some folks have also fabricated an aluminum adapter plate to use with the fuel pump in lieu of the factory bypass cover.
          #275818
            the plate over bypass   works ok  I’ve done a few , plate, nippled cover  intake manfifold  etc…  easiest will be a bypass cover with proper mounting holes  and 18-7350 pump
            #275846
            DrummermanBob
              Thanks everyone for your responses!!
              #275853
                don’t forget to plug the  air  supply  nipple behind the carb… !   and find a single line side  fuel connector  !
