Home › Forum › Ask A Member › Fuel recommendation
I’m going to fire up a 1955 Merc. Mrk – 6 and a 1956 Wizard WH-6. Given the type of pump gas that is available in So. Jersey, what should I use? Thanks, George
Regular pump gas is fine. Mix it up at 24:1 ratio with good TCW-3 rated oil.
OK
