Home › Forum › Ask A Member › Fuel tank dent repair
- This topic has 12 replies, 8 voices, and was last updated 3 years, 8 months ago by
brianlejeune.
July 20, 2022 at 11:33 am #263284
Hey folks. I was curious what some of you guys do to repair a fuel tank that’s badly dented. What I’ve done is used compressed air to try and remove some of the dents. Then use body filler in thin layers to fill in the remaining dents. The photo shows the front of the tank. Though there was plenty of dents on the sides too
July 20, 2022 at 10:28 pm #263321Sam you have that tank looking good! As for dent removal you name it somebody has probably done it. I have had to cut a hole on the inside a couple times, bump out the dent and then get the hole in the tank welded. I have many motors around here that I call Lumpy! Previous owners must have thrown the old kickers around like a football. Some members like to polish the aluminum to look like chrome. I am too lazy for that. Good luck with your paint.
dale
July 21, 2022 at 1:24 am #263325Hey there thanks for the reply! This tank was just a mess and this is the first fill restoration I’ve done. I didn’t really know if I was doing things the “traditional way” but good to hear I was on the right track. The paint color I used isn’t a perfect match but it’ll do for me. I’m using this particular project as a learning experience for future restorations on what to do and what not to do. The photo I put is what it looks like now. There’s a spot on the other side where the paint underneath the clear rippled a little. That was my own mistake. All good though
July 21, 2022 at 7:06 am #263328
Much of what I can do I learned by doing it including
removing dents from gas tanks. The tanks on the
motors I have repaired are mostly square. Simple
compared to your tank. Mostly curved but still flat on
top. And then there are those straight lines. Yikes!
That’s quite an accomplishment for your first attempt.
You done good.
July 21, 2022 at 8:14 am #263331I have a few tanks to send you for repair!
Compressed air can be a great aid in removing dents, but
be aware if you try it on a rectangular tank…….. they could
end up “round” in a hurry!Prepare to be boarded!
July 21, 2022 at 8:25 am #263332Nice job, looks good! If you do lots of these, you’ll find that Bondo is your friend.
This reply was modified 3 years, 8 months ago by
Bob Wight.
July 21, 2022 at 9:14 am #263338Awesome job. You must have been an auto body repair guy in your early life.
Brian
1947 - 2.5 hp Sears Elgin
1973 - 6 hp Evinrude (Fisherman)
1981 - 9.9 EvinrudeJuly 21, 2022 at 12:58 pm #263356Hah I wish I was. I’m actually 15 this is the first “full” restoration I’ve done
July 21, 2022 at 1:07 pm #263358Thank you! It still isnt perfect but like I mentioned before I using this as a learning experience
Sams Outboard.
July 21, 2022 at 2:04 pm #263363Your saying you want me to fix them up?
