That tank looks great Sam. You have certainly made a great job of it……..well done!
If it’s any help to you or others, should you try filling dents on a brass tank such as the British Seagull, use an epoxy filler, not bog.
I found this out the hard way recently, when I discovered that the bog won’t feather out nicely prior to painting, whereas the epoxy will.
Monte NZ
