Home Forum Ask A Member Gail Sea King 5hp GG9001C
  • #259528
    Ronald Smith
      Just finished going over a Wards Sea King, built by Gail. It is a GG9001C.  Either a 1955 or 56? Bought it for $75 last year. Carb leaked. Got a float kit from Discount Marine and installed it. Compression was good and it sparked on both cylinders. Found and downloaded carburetor manual. Set up carb as per instructions.  Fires on one pull.
      Here is my problem,  I don’t see a tell tail. Wondering whether she has a wobble and only spits? Now that it is running, I don’t want to burn it up.
      #259530
      Ronald Smith
        Here are some pictures to help identify. I believe these side cowlings make it a 1955.
        #259539
          No tell tale as such.  Water should spray out as droplets being blown out the exhaust relief slots about half way down the backside.  Yes it is a wobbler rotor style pump forward of the propeller.  Should pump at all speeds.  The rubber rotor is commonly found to be swollen from grease leaking out of gearcase.
          EDIT:  1956 Gale model 5S12.
          • This reply was modified 3 years, 10 months ago by frankr.
          #259563
          Ronald Smith
            Frank,
            Thanks. Found a source for the impeller.  Have decided that when I pull it open to inspect it’s condition, I might as well change it out.
            Officially a good strong runner.
