Home Forum Ask A Member Gale 1W4 Montgomery Ward 74GG9006
  • #9779
    cbr-thule
      First post here.
      I’ve got a Gale 1W4 Montgomery Ward Sea King 74GG9006 OB. Mixed some fuel, started right up. Is there a water pump in this motor? Where should I see water coming out when running? How do I change the impeller? Many thanks in advance for your recommendation.
      #75033
        Water slobbers out of the slots about half way down the backside. Pump is forward of the propeller. Pump rotor is part #550040
        #75047
        cbr-thule
          Thank you! Found it, some scarring on the rotor, probably needs replaced. Anything special for lower unit gear oil?
          #75059
            Lubriplate 105 or John Deere corn head grease.
            #75369
            cbr-thule
              Missing the threaded gas tank cap…. any idea where I could find a replacement or something that would work?
