Home › Forum › Ask A Member › Gale 5hp fuel pump.
Will the 0388685 pump made for 6hp,8hp,9.9 hp & 15 hp fit the Gale its looks like it will ?
It will bolt up ok, can’t say for sure about the orientation & thickness. Probably ok.
The square pump can be disassembled and the inlet and outlet clocked to any position you need.
omc_0393088-Fuel-Pump-Diagram
when placing the springs I add a small dab of crazy glue to hold them in place on their bases ….. same with the small mushrooms on top of the springs … I glue them on the springs.
that way nothing flies off to nowhere land .
OK
