Home Forum Ask A Member Gas disposal question
  • #3150
    rjoynt
      Yesterday I picked up a FD-10. A 1956 15hp Johnson. Along with the motor came a pressure tank and line. Inside the tank is a full tank of gas. OLD. Probably ten or more years old. Any ideas on how to properly dispose of the gas?
      BTW. The motor is an electric start!!!!! All for $75.00!!!
      Merry Christmas to me!!!
      #28414
      JOSEPH BRINCAT
        Old gas works great for killing poison ivy.
        Joe
        #28415
        stanley
          I run it through fine mesh strainer and mix it a little at a time to my lawn mower gas or to my old trucks gas tank.Done it for years no problem.
          #28417
            Some counties have drop off sites, or yearly
            collections at various towns in the county.
            Rob
              ^^^^^THIS.
              Pour it through some sort of strainer and mix it with the fuel of anything with a carburetor. EFI engines can get a little more finicky about that sort of thing but it never stopped me! One time, I straight up poured 2 gallons of old premix into an almost full tank in my pick up truck. The ratio was about 20 gallons of E-10 and 2 gallons of old, nasty premix. My truck (1999 Silverado) never knew the difference and that was 20k miles ago.
              Rob
              Rob
              #28421
              opposedtwin
                Yep, I have poured old premix in my gas tank and have never had a problem. Strain it first like stated above, and put some in just before you fill it up.
                #28422
                stanley
                  I use the same paper strainer funnels that I use when mixing finishes.Get them at Napa for free as a regular customer.
                  #28423
                  beerman57
                    Call your local landfill, we have a hazardous waste drop off here. Our ground water can get polluted pretty easy. We can also put used motor oil in jugs out for pick up on trash day.
                    #28433
                    1946zephyr
                      I clean parts with old gas
                      #28434
                      jerry-ahrens
                        I tried using it a little at a time in an old Nissan car I have. Didn’t have any trouble for a while until I used 50/50 old gas mixed with new. I stuck a fuel injector open, and went through complete misery fixing it myself. A reman injector for that engine was $130. I will never put old gas in my vehicle again. But that’s just my humble opinion..
                        I give all my wast oil to a local scrap yard to heat his shop with, as he has a waste oil heater. He told me he likes having some gas mixed with it. It’s easier to pump and the heater burns it fine.
