Home Forum Ask A Member Gas leak
  • #247996
    Brian McDougal
      Hello All,
      My 1925 ELTO has a gas leak at the poppit valve stem or the vent hole. A steady dip flow. How do you stop this close the feed screw more? Just open enough for demand?
      #248011
        If you mean when the motor is running
        the poppet valve (s) should stop the fuel
        when they are down. One or both of
        yours are leaking for some reason.
        • This reply was modified 4 years, 5 months ago by Tubs.
