Home Forum Ask A Member gas tank leaks
  • #262635
    David C
      Just was given a evinrude elto 4364 sportsman 2hp motor.Found out that gas tank has several pin holes.This is my first tank that has leaked and i need some advice as to what to do.Solder holes.Need to now proper method.Sealer for indside tank.Whats the best sealer? Find another tank.Not sure i want to invest much money at this point till i check out the hole motor. Any advice would be great Thanks DaveR
      #262636
      Tom
        I just finished the Evinrude version of that motor, same issue.  One of the mounting tab welds leaked after the motor was dropped on the tank.  I used the POR-15 system, it works very well.
        T
        #262651
        lindy46
          I used POR15 on a 1947 Sportsman with many pinholes and it worked well. To do the job right took many steps and was a little complicated but good results.
