Home › Forum › Ask A Member › Gas tank tips?
How do you guys get that last couple of pints of fuel out of your 2 line tanks? due to the metal lip on the inside of the fuel fill I always have a few pints I cant shake out. I’m sure you gents have some clever tips.
You can remove the drain screw, which helps.
I bought a Flow N Go for transferring now. Works like a charm.
http://www.flo-n-go.com/
Dollar store turkey baster with a piece of hose.
@ Chris_P…. Drain screw? Do you mean the screws on the top that hold the pump knob and diaphragm?
Yeah the drain plugs on the 4 and 6 gallon pressure tanks are the 2 screws immediately adjacent to the fuel and air barbs, on the filler cap side.
On the single line tanks, the screw will be marked DRAIN.
Thank you for the info! I knew you guys would have the answer
OK
