Home Forum Ask A Member gasoline copper tubing for Johnson TD-20
  • #6175
    td20
      What is the size of copper tubing for gasoline lines on a TD-20 ? Where can I buy the parts ??
      #51574
      RICHARD A. WHITE
        I would think any Auto parts store, would have copper line of the proper size… You will probably need the correct compression fittings as well.
        I like to feel rich when I look at the 3 rolls of copper tubing I keep stashed to make new lines…LOL
        classicomctools@gmail.com
        #51579
        JOSEPH BRINCAT
          The size??? likely 3/16 " , may be a little harder to find that the more common 1/4 "
          #51580
          steveh
            Actually, they are available in stock from Marineengine.com for $7.50. Part # 375269
            #51776
            td20
              3/16 inch. This will not be found at Lowes or Home Depot. They sell plumbing tubing. O’Reiley auto parts has 3/16 " tubing for a $1 per foot. I think this tubing is used for hydraulic brakes on cars.
              #51777
              RICHARD A. WHITE
                Hmm, not sure they would use copper tubing on brake lines…..???
                #51781
                  Nope, copper work-hardens and breaks. Not a good situation in brake lines.
                  #51822
                  jerry-ahrens
                    The brake line that TD20 is talking about isn’t copper. It’s the same thing that is already used an automobile brake lines.I seem to recall it’s name as ”Bundy Flex” the same company that built Bundy outboards, still in business today. https://en.wikipedia.org/wiki/Bundy_tube
