Home Forum Ask A Member Gear head Case Assembly ENV 18hp
  • #7585
    fry-cook
      Hi,
      I have an 1964 18hp Evinrude Fastwin and I am replacing the seals, impeller, etc in the lower unit It has a gear case head assembly, looks like a small can with a brass bushing. My question. Are there gears in it, or is it pretty mach a ‘passive’ unit? A new one is $167.00, is it supposed to turn /spin? or does the shaft just pass through it? How do you know if it’s good or bad?
      Thanks, Tom
      #61224
      lindy46
        No gears in the head – just a seal. The propshaft passes through it. It doesn’t turn or spin.
        #61226
          Do you have the replacement seal? It is part number 302545, replaced by 313284. About ten bucks.
          #61242
          outbdnut2
            fisherman6
              There are no gears in this piece and it does not spin as mentioned before. What it does contain besides a pocket for the prop shaft seal is the bronze prop shaft bearing. It is an important piece and I would not classify it as "passive" myself. If the bearing is worn out or scored, it will accelerate wear of the rest of the gearcase components. That said, I know most of us don’t put tons of hours on these things every year and one in marginal condition will still allow you to enjoy a motor that would not otherwise be run and enjoyed at all.
              -Ben
              OldJohnnyRude on YouTube
