Home › Forum › Ask A Member › Generic gas line not pressurized
will all generic gas line like this one
https://www.ebay.com/itm/324711324991?
fit the standard non-pressurized motor and gas tank fitting?
at that price it is the kind that gets rock hard after some time ….best to stick to the good stuff.
but will it fit, just need it to test a Johnson 92 4 hp that I have to work on. Some of the connectors ends seem different depending whos selling
4hp connector on theengine is standrad hose connectors needs to be engine manuf. specific. …even if the look alike get OMC stuff/evinrude/johnson
I do not know if YAMAHA/Johnson ?? hoses fit.
if you just want to test the engine you can do a fuel ” blood transfusion” directly into the carb to feed it by gravity 🙂 save 20$
OK
