Home Forum Ask A Member Glass bowl gasket
  • #244284
    Peter Goodwin
      I have a 1955 Evinrude 7.5. I need the gasket for the glass bowl on the bottom of the carburetor. Can’t seem to locate one or the complete fuel filter assembly.
      Thanks! Peter G.
      #244285
        I just made one up a few weeks ago from gasket material . just draw it out with the bowl and cut it with an exacto knife.
        #244286
          mikekolbus
            I have been doing what “crosbyman” has been doing using cork gasket sheets. Works great and very cost effective
            #244291
              An o-ring also works
              #244302
              amuller
                $9 for the gasket and the same again for shipping. Not really cost-effective.
                I have some gasket material that seems to be a mixture of cork and rubber, about 1/16″ thick. I would try that but soak it in gas to see if the rubber is resistant. Otherwise you can use pure cork sheeting.
                #244889
                Peter Goodwin
                  Thanks, Got some gasket material and made one. No Leaks!!
                  #244895
                  Peter Goodwin
                    Thanks for the link to Marineengines.com
