Home Forum Ask A Member Handitwin flywheel nut torque
  • #6755
    olcah
      Does anyone know the tightening torque required for a 1940 Elto Handitwin flywheel nut?
      Thank you.
      #56174
      oltimer
        I am just finishing mine off with new rings etc. Generally a 3/8" size screw (16-24 thds.) would be 18-20 ft lbs. The fly Wheel nut on 3hp Evinrude/Johnson take 30-40 ft lbs of Torque. On our Handitwin models having 7/16" size in a 20 threads per inch, I would feel very comfortable putting it at 25-30 ft lbs, but leaning more to the 30 lb side. Now you also have to consider if the Fly Wheel has been taken off the wrong way before and became egg shaped, than I would apply more or get another fly wheel. Good Luck with your unit.
        #56175
        olcah
          Oltimer, Thank you! I used a strong 25 ft-lb which was my best guess also. To get the torque wrench onto the flywheel nut I machined out/filed a hex nut to fit the nut flats and end radius. Have not tried to start it yet. If it runs well I will probably replace the muffler which was apparently dropped and cracked the casting. I like the looks and simplicity of this motor. ๐Ÿ™‚ Good luck with yours also.
          #56177
          oltimer
            I liked the looks to. As you say; it has a lot of simplicity, but well thought out design. The small tank and curved just enough to fit nicely around the unit, and I can throw this unit on my shoulder during a portage lake I like for speckled trout.
            #56191
              The Elto Handitwin would be the same as the Evinrude Sportwin. . . ๐Ÿ˜€
              #56193
              oltimer
                Garry, I already had those number from years ago when you posted, but the fly wheel on these units are very much smaller than my later year Sportwin? Sorry Garry, was looking at the later years list 1st, than the earlier list. I’m happy with my number
                #56194
                  P.S. I use a crowfoot socket on those flat sided nuts. Turn it 90 degrees counter clockwise so pulling on the handle to tighten the nut holds the crowfoot against the nut. Turned that way does not change the length so no torque calculations are necessary. . . ๐Ÿ˜‰
                  #56196
                    The earlier Sportwin is listed BELOW the later Sportwin on my list. – 25 foot pounds is correct . . . ๐Ÿ™„
