Home Forum Ask A Member HD-25 water pump 1946 to 1950
  • #160280
    GUY N BERGLOFF
      Where can I get a water pump part # 43,300,583 and also part 43,300,582 it holds the water tube above the pump
      #160282
      ROBERT T.
        I found 300582 on e-bay. marineengine.com also has it.
        #160283
        ROBERT T.
          marineengine.com also has the impeller but you may not like the price.
          #160284
          ROBERT T.
            impeller is on e-bay
            #160293
              Two club members make rotors (impellers)
              Brian Wilcox, call 810-794-7685 before 8 pm est please.Or email Baron0418@att.net. please note the b must be a capital.
              OR—
              Bob Long, http://home.earthlink.net/~flyingscott/
              #160317
              melugin
                I have managed to make these out of thick rubber, such as a pick-up bed mat or a mudflap. For the rotor, I had to glue two layers, punch or drill a hole in the center, then grind off the OD. The Johnson rotor had a relief around the ID, but the gale products didn’t. Not sure if it would actually make a difference.
                #160361
                tkwalker
                  I ordered one about a year ago and SeaWay had them in stock for ( (think) around $20 …..
