i just put in new pump on a hd 25 and still will not pump,,, i’ve noticed some replaced the gromet on end of watertube,, dose the lower unit have to be disasembled to install this and the plate that pump sets against does the pin that drives the eccentric pull out or does it unscrew,,,,thank you for any advise,,,,,
The cooling issue may well be a degraded water tube grommet/seal. The opening on the grommet is very small, and an old grommet can even swell blocking off the cooling water.
Most of the time, the grommet can be replaced without loosening the gearcase screws, but not always.
The pin that drives the eccentric, is just pressed in and usually easy to remove.
Improvise-Adapt-Overcome
This reply was modified 5 years, 8 months ago by aquasonic.
thank you very much sir…. i’ve got a new grommet on the way,,,and will remove the pin and see what is what,,,,if i run into questions i hope i can ask you ,,,,,i’ll keep you informed ….so now ,,to the bench,,,,,
If you can blow air through the tube, check that. I just went through a HD26 and the water jacket was plugged. Worth a quick check if you hadn’t already.
thank you steve yes i did and also ran water back from top to bottom and it did run out the bottom of tube,,,when tried again still no water,,, i suppect grommet,, is leaking or not sealing as i’ve been informed by guys,,,if any other suggestions please let me know i’m game to check anything,,,,
