Home Forum Ask A Member Head bolts for 1946 HD 25
  • #5302
    mark76
      Hello!
      I broke off two head bolts, drilled and retapped. What type of bolt should I replace with? Will any steel bolt from the hardware store work? Stainless steel perhaps?
      #44327
        You might be surprised to learn that stainless bolts in aluminum corrode in place worse than steel bolts do. The only advantage is the heads don’t rust.
        I’d use Grade-5 bolts, from a "real" hardware store if you can find the right length. The non-graded ones from the big-box stores are real weak, but they might be strong enough, since they don’t require a ton of torque.
