Home › Forum › Ask A Member › Head gasket for AD10M
- This topic has 7 replies, 3 voices, and was last updated 5 years, 6 months ago by
Jackson65.
September 13, 2020 at 1:06 am #216319
Hey guys,
I am in need of a head gasket for a 1956 Johnson 7.5 hp outboard (AD10M). I am having trouble finding a parts list for the 56. The 57 parts list is available and looks quite similar, and I know there are a fair amount of parts that can be swapped between those models. Can I use a head gasket for an AD12 on the AD10?If not, does someone know where I can get the correct part?Thanks for your assistance. I think I may be able to save this motor which was seized when my girlfriend drug it in. Cylinders are now turning free and look salvageable.
Jack
September 13, 2020 at 5:56 am #216320Jack, Part No. 203034 is the head gasket you need. This gasket is used on 1956-1958 Johnson 7.5 Hp, and 1954-1958 Evinrude Fleetwin 7.5 Hp. It may be used on 1950-1953 Fleetwins also, but I don’t know about that. Hope this helps.
Improvise-Adapt-Overcome
September 13, 2020 at 6:33 pm #216361Hey Aquasonic (I love your username),
That’s exactly what I needed. Thanks so much from a newbie taking on his first rebuild(s). I say rebuilds because I have two projects for I am purchasing.Jack
September 14, 2020 at 10:27 am #216401Hey Aquasonic ( or others with knowledge of AD10s),
What about the impeller and carb kit? Are those also the same as for the 57s?Thanks in advance for your expertise.
JackSeptember 14, 2020 at 10:54 am #216406Jack – carb kit is OMC/BRP #439071. Water pump impeller kit only is #379764 or #763758 for a pump kit that includes a new pump housing.
"Every time you remove a broken or seized bolt an angel gets his wings."1 user thanked author for this post.
September 14, 2020 at 1:35 pm #216421Jack, Just for your future reference, to my knowledge, the Johnson 7.5 Hp from 1956-1958 have identical parts with the exception of paint, decals, medallions, tiller grip, etc.. There’s plenty of help here, so any questions just ask.
This reply was modified 5 years, 6 months ago by
aquasonic.
September 14, 2020 at 5:26 pm #216431Thanks. I thought so, but if I had a nickel for every incorrect assumption I made, I would have lots more outboards than I do.
Jack
September 14, 2020 at 5:29 pm #216432Thanks, Bob. I am getting close to having all my parts ordered. I am going to see if I can get her back together and get her to run, then I will think about a cosmetic transformation, cause she is UGLY right now.
Jack
