Home Forum Ask A Member Head gasket replacement-Use sealer or not?
  • #11614
    elgin2
      I`ve got a head gasket ordered for a Chrysler 20hp,model 20701.Should I use a sealer on the re-assembly or not? Thanx.
      #84677
      jerry-ahrens
        Hi Elgin, here’s what I do. If the gasket has the shiny coating on it, I put it on clean and dry. If not, then use Quicksilver Perfect Seal, or another brush on type gasket sealer. This is only to seal up from external water leaks. i am guessing that your gasket is not the shiny type and will need sealer. Hope this helps!
