I have been working on a Mercury Model 40, 4HP ser # 3303202 I think it is a mid 70’s engine. CANNOT GET THIS THING TO RUN FOR MORE THEN 30 SEC TO 1 MINUTE, Here is some data I have collected and the repairs made to date.
Compression 110 psi
Very good spark
measured intake vac and pressure at the fuel pump connection reads +/_ 10 psi using a drill motor to spin engine w/o plugs
requires full choke to get it to run the 30 sec.
Repairs:
New top and bottom engine seals
Repaired fuel pump
New water pump
Clean and overhaul carb
ANYONE GOT ANY IDEAS WHAT TO TRY NEXT ? TO ME IT SEEMS LIKE A INTAKE VACUUM PROBLEM.
John
