Home Forum Ask A Member Help identifying and dating a 1920s rowboat motor
Viewing 8 posts - 31 through 38 (of 38 total)
  • #296193
    Tom
      Where is the fitting labeled “to-coils” mounted? I’ve never seen that fitting on an old Evinrude.
      T
      #296196
      Eric Reutelhuber
        It is located on top of speed control. Left prong goes thru magneto plate (looks like a stock Ingress point) and to the coil. The right prong goes to ground. Picts to follow
        #296198
        Eric Reutelhuber
          Side view of wires coming from 2 prong mount
          #296200
          Eric Reutelhuber
            View of wire from left prong connection coming thru magneto plate
            #296210
            Tom
              I can’t be sure what it is, it’s not original to the motor. There was, on the motors with those two plug in connectors, a jumper that ran across two screw on terminals. You left it in place when using the magneto, but disconnected it when boosting the magneto with a battery.
              T
              #296326
              Eric Reutelhuber
                Good evening.
                Need a little help checking the coil on the 1929 Fleetwin. Please see pict. Are these normal readings for this coil? My kingdom for a schematic! 🙂 And would you call it good?
                I get some sketchy continuity on the spring-loaded leads at the base where the spark plug wires come in contact for circuit. Is/was this really reliable?
                Rudy
                #296328
                Eric Reutelhuber
                  Best I can tell, this is the current rough schematic.
                  #296371
                  George Emmanuel
                    Eric, check your pm messages….Also, you will see 2 sets of windings, one at each end of the coil at the coil heels. Those are the winding for the power for the lights. Many times they are bad, but, you never know! And looking at your motor it does obviously have the early bakelite contacts under the mag plate.
                    George
