Home Forum Ask A Member Help identifying timer or ignition
  • #170302
    Paul Munson
      I am looking at picking up this motor for parts or possible restore. It has it’s issues and I am trying to figure out what this battery ignition is on the front. I haven’t seen one like this and I am wondering if it is something cobbled together from a couple different motors.
      00S0S_k4sb29KovyX_600x450
      • This topic was modified 6 years, 11 months ago by Mumbles.
      #170314
      lyks2tinkr
        The ignition is factory. What you have is an Elto outboard.
        The ignition timers were made by Atwater Kent and when set properly are fantastic ignition systems.
        What are the numbers on the tag on the transom clamp? They will be the model and serial number.
        #170316
        Paul Munson
          I wasn’t sure. I have a ruddertwin and the timer is great but that one looked a little different with the rounded lever and button on the end. I will get the numbers up later today if I can get them from the person holding this for me.
          #170465
          Paul Munson
            I have the serial number on the front tag now. It reads 4240551. I tried google but no luck. Anybody out there know what this one is. I looked in the Outboard Book I have, which is an older edition and if I am reading it right it skips right over 4240.
            #170473
            Tom
              It’s a ’32 – ’33 5.8 hp Model 424, serial number 0551. (If it were an 8 digit number, the first four would be the model number.)
              Tom
              #170482
                • This reply was modified 4 years, 11 months ago by Tubs.
                #170485
                  I swear Tubs must have one of every outboard Evinrude ever built – and all beautifully restored . . .
                  #170496
                  Paul Munson
                    Thank you! That was the picture I was looking for. That timer looked different than I had seen before. I looked all over the net for a picture showing that.
                    Also, thanks for helping me understand those numbers. I started thinking it might have been just the first three but I wasn’t sure.
                    #170508
                      #170510
                      Paul Munson
                        Well, here is the deal with this one. It is cheap enough $80, but it is locked up. I am hoping with patience I can get it free. My thoughts were that the other parts might be worth that if I don’t. I know I have spent more than that on fishing trips that yielded nothing so what the heck….Plus I just wanted to see that ignition setup.
